STM32N657B0 Drive the VD55G0
I want to use N657B0 to drive VD55G0, and the camera side can already enter the Stream state. After I use the function HAL_DCMIPP_CSI_PIPE_Start, I track the variable csi_instance through single-step debugging and find that several bits in its SR1 re...
eureka by Associate II
  • 2353 Views
30us delay with some constraints
Hi I am using Timer2 with Prescaler 83 and up counter of period 49 to be triggered after every 50us. But I am using an ADC and I want to turn it on every 330us. So after 6 interrupt triggers, I turn on the ADC but I need to generate a 30us delay befo...
avbST by Associate II
  • 1029 Views
How to test X-CUBE-AZURE protections
Hi, I am successfully builded and flashed TFM_Azure_IoT application at X-CUBE-AZURE(v2.3.0) package. You can see teraterm port output at attachment.I looked in to MCU software packages for B-U585I-IOT02A i found "STM32Cube_FW_U5_V1.8.0\Projects\B-U58...
macar by Associate II
  • 857 Views
