How to speed up function execution?
I'm currently implementing very low current measurement electronics, such as Femto Amps.To do this, I'm using the STM32G431CBU MCU. I'm acquiring the output voltages of a float voltage transimpetance amplifier, and I'm taking a running average.My MCU...
LIFER.1 by Associate II
  • 1291 Views
Resolved! lwIP on STM32H7: permanent memory problems
I'm running the CubeMX-generated lwIP implementation on an STM32H723. Memory addresses and configuration has been modified according to what is described at https://community.st.com/t5/stm32-mcus/how-to-create-a-project-for-stm32h7-with-ethernet-and-...
Resolved! STM32C031 - EXTI doesn't fired
Hello! I'm coding board based on STM32 C031C6T6. Everything works fine except EXTI interrupts - it doesn't fire. I use PB5, PB6 and PB7 for buttons. I checked signals on hardware - it's ok, I can register falling edge. I use external pull-up. I use C...
MLemb.2 by Associate II
  • 1181 Views
  • 4 kudos
