2026-01-15 5:34 AM - last edited on 2026-01-15 6:39 AM by Andrew Neil
Hello I am currently doing a project where I am using a STM32Nucleo-C092RC to generate a PWM signal the only problem is that my peak to peak voltege is only 160 mV. Is there any way to fix it so it is or is my board broken?
2026-01-15 5:36 AM - edited 2026-01-15 5:37 AM
What pin are you using? Don't use a pin that is already in use.
https://www.st.com/resource/en/schematic_pack/mb2046-c092rc-b03-schematic.pdf
Ensure pin speed is set to VERY HIGH.
Show how you are measuring the peak-peak voltage.
2026-01-15 6:37 AM
Welcome to the forum.
As @TDK said, you need to give more information - see:
How to write your question to maximize your chances to find a solution
2026-01-15 6:37 AM
Configuring a GPIO as open-drain without attaching a resistor and measuring with a multimeter / scope would produce similiar results.
