Resolved! Where can I buy additional 34-pin STMod+ cables and DIL socket boards as the ones for STWINBX1 ?
Where can I buy additional 34-pin STMod+ cables and DIL socket boards as the ones for STEVAL-STWINBX1 ?See attached picture for the additional parts I'm looking for - can also be used with the PROTEUS1 board but not supplied by default :frowning_face...
jea74 by Associate III
  • 3583 Views
Resolved! stlink v2 not connecting to stm32f405
Hi everyone,I recently build a custom PCB with a stm32f405, but every time I try to connect to it with a stlink v2 it gives an error. Target no device foundError in initializing ST-LINK device.Reason: No device found on target. I already managed to p...
wv1106 by Associate II
  • 7754 Views
Resolved! STM32F407IGT6 Ethernet Error
Is there an example or link where I can see the code for STM32F407IG Ethernet (UDP) communication?https://www.st.com/en/embedded-software/stm32cubef4.htmlI tried LWIP (UDP) communication by looking at the example in the link, but can you tell me why ...
Decoupling capacitor placement
Hi,I am currently optimizing some designs and started thinking about decoupling capacitors. As far as I know, it is a rule of thumb to place "one 100 nF capacitor per V+ pin".In the attached document, ST recommends exactly this. Let´s look at the doc...
RWeil.2 by Associate III
  • 13410 Views
STM32H747i-Disco LCD Driver Issue
I have been working with the STM32747i-Disco and the STM32F769--Disco boards. Both have the MB1166-A09 LCD daughter board attached. I have implemented the LCD_DSI_CmdMode_DoubleBuffer example for both. Teh H747 platform took a little more work as the...
SLimi.1 by Associate III
  • 3003 Views
Resolved! GPIO outputs are in high-impedance state
I have two of the STM32H747I-DISCO boards. I have used STM32CubeIDE to create a simple project for the boards. I followed AN5361 and am able to debug and see the CM7 and CM4 cores running.I've added code to toggle the board LEDs (port I) but don't se...
