2023-01-03 12:00 PM
STSPIN32F0 STSPIN32F0601 STSPIN32F0251 STSPIN32G4
2023-01-09 3:48 AM
Hello @FZhen.3 ,
I confirm that each part numbers that you are listed is supporting the Field Oriented Control.
You can refer to the dedicated documentation of each part numbers for more details.
2023-01-09 3:48 AM
Hello @FZhen.3 ,
2023-01-09 9:59 AM
Thanks
2023-01-10 4:51 AM
@FZhen.3 remember to "Select as Best" label in the proper reply to your original question.
So, you can help others Community member to find the answer at similar question.
If you need technical support, you can open a new topic.
