Power management
Resolved! L6924D MOS Max Current
What's the max current of the mosfet in the L6924D?We want to use AC adaptor to charge the battery and supply the system loading at the same time. So, we want to know the max current of power mosfet.Thank you.
TIENHUA by Associate III
  • 1642 Views
Resolved! STSW-DABBIDIR , where is the code.
Imagine my susprise when i discovered ST actually offers a DAB "software" for their 25KW evaluation board using stm32G474RE. And i go to ST's website.And the only downloadables are binary files and a lazy one page .pdf Am i missign something here? wh...
Javier1 by Principal
  • 1921 Views
STW3N170
I need to the FIT (failure in time) value for this part, 90% confidence level at 70 degree celsius.
MNepu.1 by Associate
  • 929 Views
Resolved! Switching frequency
HI Sir,the switching frequency below input 24V 0.04A output 12Vis that normal. the switching frequency below, input 24V 0.01A output 12Vthe switching frequency below input 24V 0.33A output 12V the circuit see below:  
L7987-DB54-24V004AC2.png L7987-DB54-24V0.01A1.png L7987-DB54-24V0.33C1.png PZha1_0-1739882991507.png
PZha.1 by Associate III
  • 2020 Views
PowerStep01 current control loop tuning
Currently we use a PowerStep01 in StepClock configuration  the current controller (CM_VM Bit set). Number of Microsteps is set to 2. Hold current (TVAL_HOLD) is set to 3 Ampere based on a 0.1 Ohm shunt resistor. All other registers are left on their ...
pf8645 by Associate II
  • 719 Views
Resolved! LED7708 Random LED switch off issue with driver
Our requirement was to create a LED driver circuit to power 12 strings of 7 LEDs from a 12V DC supply with a nominal current of 20mA per string.Using the STEVAL-ILL035V1 Development board data for PCB layout guidance and the LED7708 design tool sprea...
Resolved! Looking for an L9963E C STM32 Library
Hi everyone,I'm currently working on a project where I need to interface an STM32 with the L9963E BMS IC from ST. Before developing my own driver, I wanted to check if anyone has already written a C library for this IC and would be willing to share i...
