Resolved! Search for datasheet
I can't read référence; I am asking if this component is a zener Diode? And I'm looking for any équivalence
I found the ACS108-6SA that seems to fit my needs. 1) I will control the gate with my stm32G0B1 uC. I really don't understand why I have to connect the 24VAC Neutral to the +3.3VCC of the MCU ! It sounds like dangerous no? i can understand that the...
Hello!I am currently designing a flyback converter with the altair04-900.The .lib file in the spice model folder is encrypted. I cannot open it neither with Altium nor with ltSpice.I would like to know, which simulation software can decrypt it? And, ...
Hello, I'm considering using Viper12 to 3Phase AC/DC non isolated buck converter 5V 60mA Vout. I found some application notes like AN1357. But is it reliable? Or will it cause problems in long-term operation? Has anyone experienced it before? Thanks,...
I want the specific Ron data corresponding to different VGS values (e.g., 8V–15V) when the MOSFET switch SCTWA70N120G2V is in the linear region.
Edited by a ST moderator: Update the title and the content with the part number Hi,I'm using LD1085D2M-R regulator. There is no certain information about output capacitor ESR limit value for stabilization. -Input : 5V -Output : 4V @3A -Desired Outpu...
We are using BTA41-600BRG triacs on our temperature control boards to turn on 240V tank heaters. The tank heaters are 1500W, 3000W, or 4500W depending on the unit model and operate at 240VAC. The circuit we are using is attached. We use a FOD4108 dri...
We are looking at using the TCPP03 and TCPP01 for a system with a dual-role power port and a sink port. We want to use this dual MOSFET with both ICs (a dual MOSFET is needed for the TCPP01 to prevent backflow): https://fscdn.rohm.com/en/products/dat...
Hi Sir, I'm looking for the data sheet and programming guide for the STWLC38JRM to develop the off-line programming algorithm. Would you please share such information for reference. Thank you.
Hello,I'm developing a Qi compliant product (Not getting Qi.) using STWLC38JRM.Please respond on Operating Frequency and ASK modulation cycle to get back to the testing agency.[Operating Frequency]Qi standard defines the operating frequency from 110 ...
