Power management
I was using L4985A in my boost converter circuit. I was observing abnormal current spikes in input current waveform and audible noise is coming in no load condition itself, same in load current.Current spike coming every few seconds?
Boosting operation starts at 80Vac.It is working fine and voltage is boosted to 400Vdc as per design. Please refer the attached Input current current and duty waveform in no load condition, schematics.
Jchar.1 by Associate II
  • 2323 Views
We have purchased STeval_TTM001V1_Automotive_5kW. We have few queries related to it. 1. Increase the overvoltage limit from 36V to 48V or 60V? 2. How to enable the overcurrent protection 3. Load consumption of 5V and 3V3 supply?
1. What is the detail procedure to increase the overvoltage limit from 36V to 48V or 60V?2. How to enable the overcurrent protection as by default its disabled.3.What is the load consumption of 5V,1A and 3V3,1A power supply supply by STeval component...
PKulk by Associate
  • 871 Views
Stdriveg600: not available in the market
Hi there,​I'm doing my Master's thesis and using Stdriveg600 in my design. However, I just noticed that it's not available in the market. ​Is there any way I can get 6-8 units of​ Stdriveg600 within months? My thesis is about to end soon and I need t...
NK.5 by Associate
  • 1151 Views
"Class D" Inverter?
I need a 100 kHz, sinusoidal AC constant-voltage power supply, feeding an inductive load. Can i make a power inverter designed like a class D audio amplifier.  Except, instead of a speaker, it's a hungry power load that wants up to 20A, 5V AC power. ...
The BOOM by Associate III
  • 1047 Views
