2023-05-09 7:38 AM - edited 2023-11-20 5:56 AM
1. What is the detail procedure to increase the overvoltage limit from 36V to 48V or 60V?
2. How to enable the overcurrent protection as by default its disabled.
3.What is the load consumption of 5V,1A and 3V3,1A power supply supply by STeval components?
4.Can we use 5V and 3V3 as power supplies to external sensor circuitry: which contains sensor and signal conditioning components?
5.If inverter board is used at 48V nominal voltage do we require to mount these R83, R98, R119, R132, R145, R158 registers?
6.Where can to find 4 steps?7.How to enable Inrush current limiter?
8.What is the resolution of the current sensor used in eval board?
Please provide individual answers.
Thank you
