Power management
T435-600B Issue with Solenoid Pump and diode
Hello everyone,I'm currently facing an issue with controlling a solenoid pump using a triac T435-600B in a configuration that includes a diode. The power supply for both the triac and the pump is the same, and it's triggered by an opto. I am unable t...
pVAN .1 by Associate
  • 1865 Views
PWD13F60 abnormal behaviour
Hello everyone,I am willing to use a PWD13F60 driver to control a 200W DC brushed motor in 48V. I wanted to use the driver in full bridge so that I would control the motor in both rotational directions.To do so, I connected the HIN1 and LIN2 pins, an...
STDES-3KWTLCPL LLC circuit source code
I am developing a product based on the STDES-3KWTLCPL LLC circuit.If you go to the address below, only a "*.hex" file is attached."https://www.st.com/en/embedded-software/stsw-3kwtlcp.html"By any chance, where can I get the source code file as well?
My design with SPV1040T doesn't work Any ideas why ?
Hi ST communitiy, Here is the schematics of my design using SPV1040T chip. I used the eDesign tools to generate this schematics. The jumpers JP1 and JP2 has been closed.I just burned the chip while applying 2V 1.4A with a laboratory source. The batte...
JBegu.2 by Associate
  • 1076 Views
