Power management
Please reply my question regarding L9369 GIO
I am writing because I have a question about the L9369 chip. The second case of above table ( SPI_GIOx_HSCtrl == 0 and SPI_Off_Giox == 1) , Output  is set to HIGH. I'm curious why GIOx Output is HIGH when SPI_GIOx_HSCtrl is 0.  Thank you.
jwprk123 by Associate
  • 659 Views
Do you have a solution for wBMS?
Hi~   I am curious about the solution which referred to the wBMS I heard that you have BMS solution SOC. But I haven't heard about the wBMS. If you have, please let me know it   Many thanks BRs Daniel Lim
Resolved! LED1202QTR
Hello ST Team,We are observing that LEDs are minor glowing, during turn off condition due to leakage current. As per our application we are not not using any PWM configuration for LEDs. We are just making LEDs turn ON/OFF as per application requireme...
kadam by Associate II
  • 1228 Views
L9963E
Hi, I am MURALI SELVAM from India, We are plan to build the circuit for Battery Monitoring circuit for which I select L9963E so someone give me suggestion for ensure L9963E part number is suitable for my project, My battery spec is "6S 25200 mA/h so ...
murali by Associate III
  • 946 Views
Resolved! Reverse Recovery Time Trr of new FERD rectifiers family ?
From an ST newsletter I understood that ST is promoting new FERD diodes as "rectifiers for switching power supply". I could use these new diodes in a new flyback design so I downloaded a couple of datasheets and searched for Reverse Recovery Time Trr...
USB Device Not Recognized for STBC08PMR
Hello,On my custom designed PCB, there is a USB port for battery charging and programming ESP32 microcontroller. When I plug in to the PC, I get "USB Not recognized" message. In addition, the two LEDs are light up. In the datasheet of the charger IC ...
AE104 by Senior
  • 1236 Views
