2015-06-13 9:18 AM
I have got cosmic license file and copied it to
''license'' sub-directory of the compiler.
But while compling getting error as FlexLM System clock has been set back. I contacted to cosmic they replied asThis message means that either you have changed the clock/date system on your PC or you may have some files that have a date after the current system date. The Flexnet system is very sensitive.
What you could do is to remove or change the date of that file(s), or remove the COSMIC_LICENSE_FILE registry key and re-run the compiler.
As the software is free, there is no direct support. Support is done via the discussion forum on
#cosmic-license2015-06-13 12:53 PM
2015-06-13 1:20 PM
