Others: hardware and software
Resolved! NOR Flash long-term storage temperature range
Is there a long storage temperature range for NOR Flash or not? my home temperature is 36C i have chip ST M29W640FT 70N6 H with some recording files (maximum 10 recordings on this chip were performed) how many years approximately can this chip retain...
ÍStef.1 by Associate II
  • 2062 Views
Need to find RPM of Rotating Device
Hi all,          I need to find the RPM of Rotating equipment using Magnetic Flux .if this method is possible to find the RPM of Rotating device?.If it is possible how to convert magnetic flux(Gauss) value into RPM value . Anyone please help me to fi...
Vignesh_V by Associate II
  • 1047 Views
Resolved! M24512E-F NC pins
Hi ST Community,Are the NC pins completely isolated from the device. Wishing to know if there would be a problem with them being driven, pulled to VCC or to VSS. Thanks!
M1 by Associate
  • 912 Views
Resolved! PWM on STM8L15
Hello, I have a problem with setting up PWM on the general purpose timer. I tried setting PWM on timers 2 and 3 using different channels, but I didn't see a PWM signal at the output. I also tried setting up PWM from timer 1 and it worked, but I only ...
BamaN by Associate
  • 1813 Views
Resolved! electronics LEDs
Just joined the community! I'm pretty new to electronics and am still learning the ropes. I'm currently tinkering with a small project involving LEDs and resistors.I'm really excited to learn from all of you and hopefully contribute more as I gain ex...
