Others: hardware and software
Error creating process for executable cxstm8 The system cannot find the file specified. Failed to create process.
when i am trying to compile ST Visual develop 4.3.12 with cosmic compiler 4.4.9.0 it is showingthat the executable could not be found you can fix it by editing your too lset settings.i try to set root path as C:\Program files\cosmic\ fse_compilers\C...
Srani by Associate
  • 2447 Views
How can I find out which PDO has been negotiated
From the point of view of firmware in microcontroller, which is communicating with STUSB4500 by I2C, how can it find out what PDO (voltage and current) has been negotiated with the power source.I am particularly interested in maximum current so the m...
s_ by Associate III
  • 3479 Views
Not able to get license Key of Cosmic C compiler
Hi i am starting firmware development on STM8 based MCU. For that in need Cosmic C compiler but after its installation , for generating the key when i choose option "on the web"it does not send any mail to my registered Email address and if i choose ...
KGupt.1 by Associate III
  • 1786 Views
I have received minimum 30µA current in the STM8L Halt Mode. How can I decrease this value to the below of 30µA.
Hello Guys,I have a small problem in my STM8L device. My current remains in 30µA even in the halt mode (I would like to obtain 10-15µA). What are the ways to drop this value? I have tried to put a serial resistor to increase the total resistance of t...
AIpek.1 by Associate
  • 2991 Views
STM8S001j3 SWIM Pin lock, How to do Firmware level
STM8S001j3   SWIM PIN Not work, After hex file download (IAR EWSTM8 Compiler)8 pin port (SWIM) How to do in the firmware IAR.-DATASHEET 12page-Recommendation for SWIM pin (pin #8) sharingAs the NRST pin is not available on this device, if the SWIM...
csocom by Associate II
  • 860 Views
