Recommanded File System to use with M95P32 EEPROM
Hello,Which file system you recommend to use with M95P32 EEPROM ?My mcu is the STM32WL55, programming language C, RTOS : FreeRTOS Thank you,Sincerely.
Dose any one have experence of integrated lds6dsv32 ssc driver?I can integrated to adsp, but when driver load is fail.Any idea of it?
Good morning, I have some doubts about the functioning of the ASM330LHH. I can read the device id 0x6B, but only if I send this code: Fig1Why does it work for me? the data should not be written this way? Fig2The microcontroller I'm using is an SPC58t...
I am exploring and experimenting with the power MOSFET part number- STP8NK100Z. I want pspice models for this MOSFET. Any help is welcome.
Hello ,We need a microcontroller 8BIT 32KB FLASH 64QFP. we used MC68HC908AB32CFU that is NXP part now we want to go in STM microcontroller . Please suggest if which part is compatible with it.Thanks and Regards Pooja Katariya
May I kindly ask you the Reach and Rohs documents for the following component: STPS130U? Many thanks & Best Regards, Chiara
I am trying to use the M95020 (M95020-WMN6TP to be exact) to replace older 2K SPI EEPROMs. Comparing everything in the data sheets seems to imply it should be a good replacement, with most tolerances higher than the old EEPROM.Yet for some reason, so...
Hi, I'm looking to buy a replacement for the eeprom I've got, it's:95640RT ST k713kIs it possible to get it somewhere?Thanks in advance!
I saw somewhere in the forum that the TOF sensors see [optical] pings from other sensors as ambient light (meaning they are able to ignore them) but are still able to detect their own bounce. Is that true? If yes, can someone explain how that works...
In this package for IDB05A2 https://github.com/STMicroelectronics/x-cube-ble1 In the file Drivers/BSP/X-NUCLEO-IDB0xA1/stm32_bluenrg_ble_dma_lp.h there are few includes : #include "stm32f4xx_nucleo_bluenrg_dma_lp.h" #include "stm32f4xx_hal_bluenrg_...
