Others: hardware and software
Separate CSV files in SD card by NAME
Hy guys, I'm having some issues trying to come up with a solution to separate CSV files in an SD card by name.My intention is that every time I turn on my board, it compares if there's already a file with that name, if so, it creates a differente one...
FPicc.1 by Senior
  • 1178 Views
STULPI01BTBR
Hi can you share us EVM for the following STULPI01BTBR bridge IC.Can you share us the whether we need to use Battery for the VBAT pin or else we can use regulator output 3.3v.VB_REF_FAULT & VBUS pin interconnection details.RegardsIrshath
Irshath by Associate
  • 889 Views
need to make program
below is my hard ware configurationwe need to make code in C#  to send and receive string in same device can any one help us to make this code please USB Printing Support S STMicroelectronics [0x0483] TC421 Wireless Programmable LED Time Controller [...
amitp by Associate
  • 976 Views
Automatically Register value changing
We are using SPINFamily Evaluation Tool 3.2 with EVLPOWERSTEP01 device for operating the stepper motor. Once we programmed the parameters the stepper motor was running with some speed e.g. 411.37 step/sec but after some time stepper motor step/sec su...
Quarry About STM8S Programing Erase
Hello everyone,I am Prashant . I try to program STM8S001 microcontroller once I flash the code of UART and I initialize TX pin 8(PORT PD5) or 5(PORT PA3) after that i am trying to flash code again in controller but it's giving me SWIM Communication E...
Resolved! VN330SP vs. VN330SP-E
Hi @ all,what is the difference between VN330SP and VN330SP-E or what does the suffix -E stand for?I have compared both datasheets and found no differences. Thanks a lot for your replies!Phil
