2024-10-19 5:43 AM
2024-10-31 8:09 AM
Hi @vkosuri ,
Open the board box and make sure that the battery connector is inserted correctly. Connect a cable to a low-Power USB port, do not use high-power ports.
If you have a sensortile.box check that the LEDs light up in sequence.
If you have a sensortile.box pro, check that the green and yellow power LEDs light up.
If doesn't work, try to change a usb cable or port used.
Let me know if you solve the problem!
