2026-04-09 5:13 AM - last edited on 2026-04-09 5:37 AM by Andrew Neil
Split from Any accelerometer supporting >400g with integrated free-fall detection ? - this is a separate question
Hi Team,
Could you please suggest a suitable wireless development board that supports LSM6DSV320X, or any latest high g accelerometer sensors, apart from Sensor Tile Box Pro?
2026-04-15 8:37 AM
Typical solution would be STM32WB5MMG host MCU, 16-128 MB QSPI flash for data logging, LSM6DSV320X, LIS2DU12 as watchdog accel, STBC08 battery charger and JST battery connector, USB-C and tag connect, rgb led, etc in a ~1 sq. inch 4-layer pcb. Idea is a small, wearable, ultra-low power device for data logging or streaming via BLE.
2026-04-11 6:04 PM
Probably need a custom solution.
2026-04-12 10:07 PM
Hi KWine ,
Thank you very much for your suggestion. Could you please provide a possible custom solution? It would help guide the procurement of the required hardware.
2026-04-13 3:10 AM
2026-04-13 9:13 AM - edited 2026-04-13 9:31 AM
Please send a private message to discuss.
2026-04-13 9:20 AM
Note that this is a public forum, visible to everyone on the web - so you might wish to reconsider publishing your email address to the entire world ...
The forum does have a private messaging facility.
2026-04-15 8:37 AM
