ims330dlc Gyro signals
Hi Does anyone know how to stabilize the gyroscope and accelerometer signals. I am getting signals back but I am trying to move a radio button on a bullseye and can't seem to smooth out the signal. I am using I2C communications.
ODR rate on ISM330DHCXTR
Hello, I'm using (ISM330DHCXTR) accelerometer to calculate the phase difference between two axes to measure the movement of a system. configured ODR at 6.6 KHz and measured the operation frequency of the system which has a 10% error while measuring t...
LIS2DW12 accelerometer Arduino
Hi     I am looking for example code for the LIS2DW12 using Arduino code . I am using an Expressiff module esp32 C3  Does anyone have some example code ?
Pro-tec by Associate
  • 459 Views
Resolved! Sensor TileBox Pro
We want to use the Sensor TileBox pro to measure temp pressure and acceleration in structures.   We have been using some of your boards the MKI versions and they will run at a maximum of 1400 time steps per second when configured for about 2000.   I ...
LIS2DUX12 machine learning core advice
Hello. I have LIS2DUX12 accelerometer and have sucessfully ran machine learning example from STMems (activity_recognition_for_mobile) on our custom hardware.https://github.com/STMicroelectronics/STMems_Standard_C_drivers/blob/master/lis2dux12_STdC/ex...
LPetr.1 by Senior II
  • 466 Views
Resolved! ISM330DHCX temperature reading?
Hello,We have the ISM330DHCX designed into a new product but I am having trouble getting reliable readings using the I2C interface. I am able to read the WHOAMI register and get 0x6B but OUT_TEMP_L (20h), OUT_TEMP_H (21h) always return zero.I have th...
Resolved! Confusion about LSM6DSM and lis3mdl integration
 Hi everyone,I am working with the  LSM6DSM and an external LIS3MDL magnetometer and have the FIFO ODR set to 208 Hz, with no decimation configured.I am trying to understand exactly how the FIFO handles data in the following four scenarios. Could som...
Purvesh by Associate
  • 388 Views
Resolved! iis3dwb Sampling Rate Driver Issue
While using the iis3dw sensor, I discovered that when I employed an interrupt-based polling method to read data—where, ideally, the sensor captures data, triggers an interrupt, and then the data is read—the data acquisition frequency should be around...
Leo_leo by Associate
  • 287 Views
