VL6180X API example code?
Posted on March 04, 2018 at 22:07Does anyone know where can I download the VL6180X API example code?The product page does not have the download link.http://www.st.com/content/st_com/en/products/embedded-software/proximity-sensors-software/stsw-img00...
LIS3DH Interrupt always high
Posted on May 24, 2017 at 22:07With the configuration below I'm attempting to receive and interrupt from INT1 when there is acceleration along the Z axis. However INT1 alwyas stays high...Not sure whats going on//ctrl_reg1 LIS3DH_WriteReg(LIS3DH_CTR...
LSM303AGR: Interpreting the values read
Posted on February 28, 2018 at 18:37Hey there!Can anyone explain to me how to calculate the correct acceleration values in mg for various resolutions and scales?For example, I am currently reading acceleration values with  ODR set to 0110, which is ...
Any problem if the NC pin in LIS3DH is connected to GND?
Posted on March 05, 2018 at 07:46In many other IC I saw NC pin being connected to GND. However, in LIS3DH, it is not recommended that we should leave it floating or connect it to GND. So I'm wondering if there is any problem if we connect the NC pin...
Vu Tran1 by Associate
  • 1086 Views
ISM330DLC Working Procedure.
Posted on March 03, 2018 at 10:30Hi,We have integrated ISM330DLC driver with our Linux Kernel and we wanted to test both accelerometer and Gyroscope at the same time.Please let us know how to configure the interrupt for each of the sensor Accelerome...
Customizable GPS module
Posted on March 01, 2018 at 16:06 Hello, please i would know if ST provides customizable GPS processor or customizable GSM processor. Thank you. Note: this post was migrated and contained many threaded conversations, some content may be miss...
FIFO Setting in LSM6DS3 - 3D Accelerometer and 3D Gyroscope
Posted on March 02, 2018 at 15:39We were using NXP's MMA8451Q Acceleroemter for one of our application which involves collecting raw data through FIFO buffer. Here, application notes having explanation and example code snippets helped a lot for the ...
Resolved! LSM6DS33 longevity
Posted on February 21, 2018 at 22:43Hello,We're using the LSM6DS33 accelerometer/gyrometer in a product, which is expected to be continuously manufactured for ~5 years. I'm slightly worried about its longevity. I know that nowadays it is listed as A...
