OPC value
Posted on March 01, 2018 at 18:59How does a integer value correspond to the value to be stored in RPDS(18 h and 19h)? For example if I want to reduce the absolute pressure by 10hPa what value needs to be passed to these registers? Thank you in advan...
MotionFX and output data rate
Posted on March 01, 2018 at 07:18From section http://www.st.com/content/ccc/resource/technical/document/user_manual/group0/31/0e/66/39/cb/f7/4e/cd/DM00394369/files/DM00394369.pdf/jcr:content/translations/en.DM00394369.pdf:It is important to set up t...
Norman S by Associate II
  • 702 Views
LSM303AGR: reading acceleration values
Posted on February 27, 2018 at 19:50Hey there, I am currently trying to read some acceleration data with the LSM303AGR via SPI.In order to do so, I have already set up the SPI and accelerometer and I have accomplished to readthe who_am_i register su...
lis2de12 based Question
Posted on February 28, 2018 at 08:30Hi AllMCU:STM32l432KBUSensor : lis2de12  accelerometerInterface : I2CI used above information in my projectSo Please share me  step or sequence how to read data(Sample) from accelerometer using i2c #mems-gy #lis2d...
LSM303AGR tilt compensated e-Compass
Posted on February 27, 2018 at 16:03Hello,We are using the LSM303AGR e-Compass in a wearable device and I am trying to obtain a tilt compensated heading. I followed the ST DT0058 document (Computing tilt measurement and tilt-compensated e-compass), ...
0690X00000609lMQAQ.png 0690X00000609o0QAA.png 0690X00000609pIQAQ.png 0690X00000609q0QAA.png
LIS3DH stops sampling measurements after some time
Posted on January 24, 2015 at 22:56We have noticed that the accelerometer stops sampling after some time (10+).  When that happens, the only work around is to write 0x0 in REG4, and then re-writing the original value of 0x37.  Anyone has encountered...
javier2 by Associate
  • 2736 Views
Datasheet seems incomplete for LSM303DLHC
Posted on February 16, 2018 at 04:29I am trying to develop a driver for my project which uses this Accelerometer / e-compass and while there is plenty of information for me to get something working, it is missing some information and some informatio...
How much is the current consumption of LIS3DH in FIFO mode?
Posted on February 17, 2018 at 12:00I am seeking about the average current consumption of LIS3DH in FIFO mode (@10Hz). In its datasheet the current consumption in Low power mode, Normal mode, and High resolution mode is said to be 3~4 uA. I used the...
What accelerometer is used in the LSM330DLC?
Posted on February 06, 2018 at 16:45It is my understanding that the LSM330DLC is a 'System-In-Package', that is it is a separate accelerometer and gyro die packaged together. What are the actual die part numbers?The reason I ask is that the LSM330DL...
