What is PDM format?
Posted on March 17, 2017 at 17:25Hello,I want to use MP34DT01 microphone in our application. But data stream format is unclear. Explain this please. I guess this is the usual delta modulation. Is not it? Analog Devices for ADMP521 was describe it tr...
X-NUCLEO-53L0A1 with Nucleo F030R8
Posted on August 10, 2016 at 16:46Hy,what would be the easiest way to use the VL53L0X Nucleo Expansion board (X-NUCLEO-53L0A1) with Nucleo F030R8?All given examples rely on a F401, the source code would not work immediately, because there are some f...
harald by Associate III
  • 1570 Views
F401RE VL53L1X debug issue
Posted on March 21, 2018 at 15:51Hello,i'm quite new to the embedded world and purchased the VL53L1X evaluation kit with the F401RE and thehttp://www.st.com/en/ecosystems/x-nucleo-53l1a1.html. I installed all the drivers and the System Workbench on ...
LIS3DH
Posted on March 07, 2018 at 14:03Hi Sir,I am using ST accelerometer Sensor  LIS3DH (adapter board STEVAL-MKI105V1) with I2C interface.I can now read the registers. But for the registers which doesn't have default value, for example,OUT_X_L (0x28),OU...
Arna Lee by Associate II
  • 4291 Views
LIS3DH current consumption
Posted on January 16, 2017 at 13:36 Hello guys, I'm using LIS3DH accelerometer in my current design. I need it to detect the movement. ODR is set to be 10Hz. According to http://www.st.com/content/ccc/resource/technical/document/application_n...
bojan by Associate II
  • 8206 Views
  • 19 replies
Resolved! LSM303AGR: Magnetometer Interpreting values
Posted on March 20, 2018 at 18:33Hi!Fairly new to programming and embedded software in general but I'm having a problem with interpreting the values I am receiving from the magnetometer registers.I'm able to get a value between 0 and 255 for each re...
