MotionFX: Different between implementation for M0 vs. M3
Hi,i am trying to use the MotionFX library on M0 MCU for LSM9DS1. As result i read the rotation_9X structure and use yaw as heading for compass result. The result showing the rotation but i see the offset on the Z axis of the gyro and the heading res...
drozel by Associate II
  • 2329 Views
Cannot access mag registers on LSM9DS1
On about 15% of the boards in my latest production run I am able to access the accel/gyro registers over the I2C bus but cannot access the magnetometer registers. As a simple test I am trying to read the WHO_AM_I register (0x0F) for both. I get the...
Using the LSM303 right out of the box
 Will I get meaningful data if read the registers without any register modification or do I have to set the registers first. Sorry I'm very new to ST products and I would like to incorporate into my product.
CGlas by Associate
  • 1120 Views
STEVAL-MKI109V3 Dfuse update issue
Hello,I am trying to get the STEVAL-MKI109V3 upgraded to support the STEVAL-MKI179V1.When I first tried to use the 109V3, Unico said my firmware was out of date and needs to be updated to support the 179V1.So I used Dfuse to update the part. I am usi...
LCorb by Associate
  • 931 Views
LPS22HB as pressure sensor
I try to use the LPS22HB as real pressure sensor (measure of force against the skin, but I almost didn't see any change. Only when press with big force I see the change.Does the name of barometer mean it can't sense pure pressure against its window?
Barbie by Associate II
  • 2219 Views
LPS33HW SW & EV board
If I want to test the LPS33HW and I already have the X-NUCLEO-IKS01A2 motion MEMS place over STM32 Nucleo test by DataLogTerminal SW from X-CUBE-MEMS1 package.I see there is LPS33HW EV STEVAL-MKI183V1. But I didn't see any reference to use it on the ...
  • 1328 Views
