Transferring PDM_OUT from MP45DT02 to CS43L22
I want to access PDM_OUT data from the MP45DT02 and output this on the CS43L22. For this I want to use the I2S protocol but I have difficulties connecting the MP45DT02 to the I2S mode and using the HAL_I2S_Receive function. How do you initialize the ...
JtotheF by Associate
  • 1128 Views
VL53L0X CALIBRATION
Hello, I am writing this message to you because I need help, if it is possible I would be grateful to you .. Ok, I am working on a project in which we will use the VL53L0X as a sensor in an access control device , we will use it as a proximity sensor...
MSAMB.1 by Associate III
  • 900 Views
VL53L0X Offset Calibration Procedure Examples?
I'm using an array of VL53L0X for a robotics application, and I'm struggling with the problem of offset calibration. I have looked through the API, but I get lost pretty quickly. Can you point me at any working tutorials and/or examples showing how...
FPayn.1 by Associate III
  • 854 Views
SensorTile.Box hangs when logging acceleration data to SD card
I am trying to log acceleration values, time and date over a longer period of time. (8 hours)After an undefined time (often after about 1h) the green LED will no longer flash. If the SensorTile.box is supplied by a power supply, you can see that the ...
KBerg.1 by Associate II
  • 1953 Views
