We are in production of a product designed for continuous outdoor deployment. The enclosure is IP67 with a Gore vent to allow access of water vapor (for humidity measurement). Hence, the PCB must be conformal coated to protect against corrosion/oxi...
Hi I want to use the continues mode feature, so I can read and write from the buffer simultaneously. I have trued to find an example, do you have anything that help?
S'agissant de la dernière question et selon le guide (version 4.0 de juin 2017) des exigences applicables aux substances contenues dans des articles, je cherche à savoir si lors de son incorporation dans l'article, la composition de la substance ou d...
The Analog Devices ADXL355 evaluation kit worked right out of the box. I have downloaded at least three installers and five PDFs, and all I have to show for it is a bleeding thumb.
Hi Team,We had put LIS2DE12TR in our camera design whose 2nd proto manufacture is to be started in 1st week of August.But the part is not found in stock at Digikey or Mouser.Found some stock with but the date code is 2012.Please check and confirm if ...
The target of our educational project was creating a vibration sensor based on a MEMS-accelerometer. We found that housing itself of completed device and method of placing PCB in housing has a significant effect on instrument readings. This effect is...
I want to get data from fifo every 30 seconds but I need to set my system time to every sample, so I need to know how many time or what the accuricy in 52 HZ to set time when I read the data from FIFO
Hi guys,Now I have some troubles with 2 VL53L1X that measure the distance at the same time but I can't init these sensor ? Here my code I code on Esp32. I'm using SparkFun libraryhttps://github.com/sparkfun/SparkFun_VL53L1X_Arduino_Library.git#includ...
