Resolved! VL53L3CX-Satel - i2cdetect keeps changing.
I got the VL53L3CX-Satel kit and it is behaving very strangely.I connected i2c pins (SDA and SCL), GND and VDD (3.3V).I get different addresses every time I run i2cdetect:devboard:~ $ i2cdetect -y 1 0 1 2 3 4 5 6 7 8 9 a b c d e f...
Mdo N.1 by Associate
  • 1660 Views
Resolved! VL53L1X Long-distance Ranging sensor: I have planned to integrate this sensor into my board. How is the I/O supply of 1.8V (standard mode) generated internally from the AVDD supply? Will there be any issue when I provide 2.9V (or) 3.3V supply to AVDD?
On my board, I have two supply options within the permissible range of this sensor (2.6~3.5V) i.e. 2.9V & 3.3V. Will there be any switching noise coupling to the power supply due to the ranging operation of the sensor? Are there any recommendations t...
MM.11 by Associate
  • 1209 Views
Resolved! Why does ST VL53L0X library always return RangeStatus non-zero
We are using the VL53L0X sensors in their default configuration supplied out of the factory. We run VL53L0X_DataInit() on the sensors and then every 100ms call VL53L0X_PerformSingleRangingMeasurement(Device, &measure). Upon return, we check measure.R...
Resolved! How to use VL53L0X_CHECKENABLE_RANGE_IGNORE_THRESHOLD
We tried to use VL53L0X_CHECKENABLE_RANGE_IGNORE_THRESHOLD.But not found any effect on measurement reading.If you share some input for way to use VL53L0X_CHECKENABLE_RANGE_IGNORE_THRESHOLD, then it will be very useful.
YGude.1 by Associate II
  • 1378 Views
