What is the maximum value of external pull up resistance of LiS3DH?
How can we find the range of external pull up resistance ?
10K Pull up is mentioned in the data sheet
Hi, I have been investigating a current leak in my circuit. I triangulated it to my IIS3DWB, when the accelerometer is not communicated through and all pins are pulled up by the MCU, I get a system current consumption of ~20uA (expected) But if I eve...
We received notification from our CM that there is an EOL notice for this part. I checked a few sources including st.com, and they all say that this part is active. Can you please confirm the YTEOL for this part?Thank you.John
Hi,We are trying to get Accelerometer without gravity kindly let us know if there are any possible way to get the same.Regards,Dwithi
Considered standard bus capacitance for the resistor calculation is 400 pF.
