Read lsm6dso32 data via libiio
We are trying to use lsm6dso32 accelerometer/gyroscope connected to a custom hardware (non-st) via i2c. What we want to achieve is reading measured values continuously, ideally via libiio (buffered).We are building a custom linux (kernel version 5.4)...
NKuhn.1 by Associate II
  • 2574 Views
Resolved! TDM interface with SAI for LIS25BA
Hi,I try to use a custom board with LIS25BA.I use SAI with STMF446.What I know :MCLK = 12.288 MHzWCLK = 16kHz8 slot with 3 activeso BCLK = WCLK * (8 * 16) = 2.048 MHzWhat I can do :I2C works like a charm ;)What I can't do :Configure SAI with these va...
Axoul by Associate
  • 1776 Views
LIS2DS12 3V3 alternative
Hi,I used LIS2DS12 in a previous design and i appreciated the high number of embedded function, expecially the integrated step counter; unfortunately i cannot use the same accelerometer in a new design since my power supply is 3V3: is there any equiv...
MColu.2 by Associate
  • 1135 Views
I am using an ISM330DHCX device. I want to know how I can program the device to read the 12 registers, OUTX_L_G thru OUTZ_H_A in a continuous mode.
I know that CTRL3_C, IF_INC defaults to auto-increment of register address.I am trying to stream accel/gyro register data from the device by sending a SPI read command to register OUTX_L_G. The SPI controller is configured to read 12-bytes. The regis...
DBash.1 by Associate
  • 1337 Views
LIS2DW12 Getting Falling Interrupt with Status register value 0 ?
Hello Support Team,I am working on the LIS2DW12 Sensor with Wake-up feature.Issue :Getting Zero on ALL_INT_SRC (3Bh) read while Falling interrupt occurred.Description :Configuration : Operation :Why does Falling Edge interrupt show Interrupt status a...
ChintaN1 by Associate III
  • 704 Views
