lsm303agr power-down current consumption?
I have several lsm303agr that with the accelerometer and the magnetometer in power-down mode consume between 40uA and 20uA while others consume about 2uA as indicated on the datasheet.Even if they have this higher consumption, they perform the self t...
CSharpino by Associate III
  • 3373 Views
What should be the register setting to get both free fall detection and motion detection in low power conditions in LSM6DSO32?
Hi,We are using LSM6DSO32 Sensor in our device. For our application we need two things(Should be able to operate in low power),1) Free fall detection (if device falls down, interrupt should be generated)2) Motion detection (if device is in motion/at ...
NIVI by Associate III
  • 2595 Views
LIS3MDL going dead after few usage
Hello everyone,I need help regarding LIS3MDL magnetic sensor aka compass issue is i am using this sensoron my custom made gps pcb which is then used by my quadcopter the issue is that it works fine at the very start but after few usage when i connec...
RMish.1 by Associate II
  • 3225 Views
Resolved! LIS2HH12 does not respond on SPI
Hi,I'm trying to get the LIS2HH12 accelerometer to work via SPI. The message I'm sending seems correct to me, and all the timings are within the minimum and maximum specifications that I have found in the datasheet. I have tried multiple SPI configur...
TSnym.2 by Associate
  • 1971 Views
Resolved! Sensortilebox serial port issue
I have tried many things to get my pc to recognize the serial port of my sensortilebox, i have windows 10, so i shouldnt have this problems. Some know how to fix it?
SAbba.1 by Associate III
  • 1775 Views
Resolved! Weird CubeIDE behavior when trying to use MEMS library
Hello!This is what I have done yet:I started by launching STM32CubeMX and creating a new project for my specific STM32 Nucleo board.Once the project was created, I moved to the Pinout & Configuration tab. There, I enabled the I2C1 peripheral. I then ...
_legacyfs_online_stmicro_images_0693W00000bl0QzQAI.png _legacyfs_online_stmicro_images_0693W00000bl0RJQAY.png
DLid.1 by Associate II
  • 1911 Views
Resolved! Timeout when i try to overwrite apps on SensorTile.BOX (Entry Mode)
Estoy probando el SensorTile.box y he intentando reiteradas veces probar alguna de las aplicaciones que ya están diseñadas, he intentado en IOS y se queda cargando el overwrite y nunca termina, y he probado en Andriod y me da un error de Timeout.¿Alg...
  • 5149 Views
