2017-10-11 11:52 AM
Hello! I have an issue with SPWF01SA11 one-way SSL/TLS connection. I am sure I check all similar cases here, but still can't solve my problem. I tried certificates from tutorial en.STSW-TLSpack example_2,
tried to generate my own certificates and got
ERROR: Unable to load CA certificate.
And now I am trying www.geotrust.com/resources/root-certificates/#.Through teraterm send commands:
AT+S.TLSCERT2=clean,all
OK
AT+S.SETTIME=1507665904OK
AT+S.TLSDOMAIN=f_domain,GeoTrust Global CAOK
AT+S.TLSCERT=f_ca,1216-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----OK
AT+S.TLSCERT=f_content,0
# TLS loaded CERTs:# CA Cert: YES# Client Cert: NO# Client Key: NO# Domain Name: YES - GeoTrust Global CAAT+S.SOCKON=ssltest11.bbtest.net,443,s,indERROR: SSL/TLS Error: Unable to connect (-308)
What is wrong? Please help me! I waste about week for that (((
2017-10-12 12:17 AM
Hello Viktor,
seems you put as domain name the Common Name of the Certification authority (CA).
You have to put in this field the domain name of the Server you want to connect with. Very likely you will need to use this command:
AT+S.TLSDOMAIN=f_domain,ssltest11.bbtest.net
but check inside the server certificate if this is the actual Common Name.
2017-10-12 8:07 AM
Adriano, thank you for your reply. I tried that case too before - doesn't work. Maybe you will see the problem with my local certificates. My steps:
openssl genrsa -out rootCA.key 2048 \\ CA key
openssl req -x509 -new -key rootCA.key -days 10000 -out rootCA.crt \\ CA cert
openssl genrsa -out server.key 2048 \\ server key
openssl req -new -key server.key -out server.csr \\ server cert
openssl x509 -req -in server.csr -CA rootCA.crt -CAkey rootCA.key -CAcreateserial -out server.crt -days 5000 \\signature
openssl x509 -in rootCA.crt -out rootCA.pem -outform PEM
openssl s_server -key server.key -cert server.crt -tls1_2 -accept 4433 -www \\ runserver
openssl s_client -connect localhost:4433 -CAfile rootCA.pem // Verify return code: 0 (ok) Extended master secret: yes
openssl x509 –text –in rootCA.pem –noout // check Looks like keys work with server
OK
OK
AT+S.TLSDOMAIN=f_domain,1.150
OK
AT+S.TLSCERT=f_ca,1254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OK
# TLS loaded CERTs:
# CA Cert: YES
# Client Cert: NO
# Client Key: NO
# Domain Name: YES - 1.150
OK
AT+S.SOCKON=1.150,4433,s,ind
I tried load certificate like ctrl+c/ctrl+v and send a file through the teraterm. But the same error.
https://ssl.gstatic.com/ui/v1/icons/mail/images/cleardot.gif
________________ Attachments : rootCA.pem.zip : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006HyNK&d=%2Fa%2F0X0000000b6o%2Fs6NAlyek5hjcVD8JInYbsyAZOEZVyOiSvLpi_BTQUMo&asPdf=falseserver.crt.zip : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006HyEd&d=%2Fa%2F0X0000000b6l%2Fvkte839fKhmoxdkgkn_9fpDbmu3td3P4uvrBy1SBjek&asPdf=falseserver.key.zip : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006HyNF&d=%2Fa%2F0X0000000b6n%2FwBi0llE1t155WunwsUa1S_q7rbrYZUbkrZleNu7ysDg&asPdf=false2017-10-12 8:32 AM
Looking at your generated server certificate I've seen that you've used as Common Name (CN) field for you server certificate the string 'server'. Use that as your domain:
AT+S.TLSDOMAIN=f_domain,server
Usually this field is filled with the URL of the server, and the TLS protocol check if the server is actually the one claimed by the certificate.
Let me know if this solves the issue!
Bye
2017-10-12 9:07 AM
AT+S.TLSDOMAIN=f_domain,server - I tried with this parameter before, for
sure! but the same. And one of the similar topics I found the script for
generating certificates RSA1024_oneway-auth.sh. With that didn't work
either
2017-10-12 9:34 AM
Ok, let's do another try...
Your former AT-command to open the socket was this:
443
,s,indBut in a later message you put the openssl command for start the server:
4433
That uses another port number...you have to use the same port number, otherwise the connection cannot work!
Try this and, in case didn't work, list here all the commands and output received, also from openssl side...
2017-10-12 9:43 AM
There are two different ways. When it possible, please help me solve the
problem with my local certificates. AT+S.SOCKON=192.168.1.150,4433,s,ind. I
sent all my steps in my second post with attached certificates were
generated before. Please forget about the case with ssltest11.bbtest.net.
I am sorry for confusing you!
2017-10-12 10:18 AM
I created new certificates on ubuntu machine (under win10) and run the server. Now I get
ERROR: SSL/TLS Error: Unable to connect (-150)
and on server side
'bad gethostbyaddr
140682958407320:error:140940E5:SSL routines:ssl3_read_bytes:ssl handshake failure:s3_pkt.c:1210:'When I try to do with the same certificates on windows machine - 'ERROR: Failed to connect' and nothing from the server side.
About change
'CR+LF'
- 'CR' - doesn't work for me. Get ERROR: Unable to load CA certificate. Now, when just copy/past or send file rootCA.pem get Error: Unable to connect (-150). I believe, when server get some response, I am on the correct way )))
2017-10-12 10:50 AM
Ok, I've tried to make some tests on my side with your certificates and maybe the solution was on the Teraterm settings...
The first try I've made was unsuccessful (error reported: Unable to load CA). My Teraterm setting for carriage return was 'CR'.
The only way I was able to make the connection working was to set the carriage return to 'CR', then put the command AT+S.TLSCERT=f_ca,1254
and press Enter. Before putting the certificate, I've switched the carriage return setting to 'CR+LF' and then put the certificate inside.
With this configuration I was able to open a secure connection with the server.
Here's my output:
at+s.tlscert2=clean,f_ca
OKat+s.tlscert=f_ca,1254
-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----OK
at+s.settime=1507822368OKat+s.sockon=192.168.0.3,4433,s,ind ID: 00OK
+WIND:55:Pending Data:0:ENC
at+s.sockq=0 DATALEN: 5OK
at+s.sockr=0,5ciao
OK
Did you generate the certificates on a Windows machine? Usually I generate them on Linux and this mess with the carriage return doesn't appear...
2017-10-12 11:00 AM
sorry I forgot one important command:
at+s.tlsdomain=f_domain,server
at the beginning
