Comms between 2 x IDW01M1 boards
Posted on October 19, 2017 at 18:24Hi,I am working on the IDW01M1 wifi module. To-date I have been able to connect 2 of these modules to a common server and send commands between them via the server. I am now trying to connect directly between the m...
daithi62 by Associate II
  • 850 Views
Resolved! How close socket AT+S.SOCKC?
Posted on October 19, 2017 at 15:03Hello! I cant close socket client be command AT+S.SOCKC -  “ERROR: Pending dataâ€� is raised'.  According to UM1695 it should be flushing pending data  (using the AT+S.READ command) is mandatory before closing th...
BLE central application and low power
Posted on October 18, 2017 at 10:58Hello,I'm pretty new to BLE devices. I intend to develop a BLE central application device that needs to run in low power most of the time. This central device will be paired with some other slave devices arround. M...
Generating BLE 128 bit Custom UUID
Posted on March 15, 2017 at 10:48Hi,What is the best way to generate custom BLE 128 bit UUIDs ?How has ST generated the custom UUIDs in the firmware examples of Sensortile kit related to BLE ? For example, following are some UUIDs(in bold) in one of...
RADS1 by Associate II
  • 3905 Views
