HTTPDFSUPDATE failed
Posted on April 19, 2016 at 15:27Hi, I am having a problem with the HTTPDFSUPDATE failing mid download here is what I see on the console:  Image length 338827 (offset 0x00080000, block len 4096)  Write len 4096 -> 0x8B000                            ...
toby by Associate II
  • 1195 Views
SPIRIT1 AES128 commands estimated time
Posted on April 21, 2016 at 15:13Hello, Can someone specify how many time is needed to execute every one of four AES co-processor commands. That is: Encrypt, Generate Decryption Key, Decrypt, and Decrypt with Encryption Key. Thanks
lz1im by Associate II
  • 628 Views
Not able to use BlueNRG !
Posted on April 12, 2016 at 06:56hi,I am using BlueNRG bluetooth module on my customized board with MSP430 mounted on it.I wanted to know:1) Can we use ''ST BlueNRG'' with ''TI MSP430'' mcu ?2) If yes, what all steps do i need to take to initialize ...
puru by Associate
  • 722 Views
nrf51822 advertising without antenna
Posted on April 11, 2016 at 10:50hi, Can nrf51822 advertise with a Balun(bal-nrf02D3) whose SE pin is disconnected? (not connected to antenna / SE pin left disconnected)Should it at least advertise weakly? or no signal at all?And Is there a way to t...
jonghwa by Associate
  • 698 Views
Using Nabto + SPWF module?
Posted on April 08, 2016 at 11:17Hello, does anybody know if it is possible to use the SPWF module in combination with Nabto? https://www.nabto.com/ There is a Nabto FreeRTOS plugin, so it would be a nice solution with CubeMX --> FreeRtos --> STM32...
SPMW01SA HTTP post with JSON format
Posted on March 16, 2016 at 16:03Hi All,For my project i am using SPMW01SA WiFi module and still we are in development stage so we are doing our R&D on STEVAL-IDI004v2 evaluation board.STEVAL-IDI004v2 board WiFi is able to connect to internet and wh...
