S2-LP Signal Testing
Posted on March 15, 2018 at 15:57Hello,I'm currently evaluating the S2LP radio chip on an FKI868V1 and I'm trying to reach sensitivity marks described in the datasheet.I'm having trouble getting the kind of sensitivity expected when testing at 300 b...
Resolved! STEVAL-IDB007V1M not transmitting at all
Posted on March 19, 2018 at 11:41I'm trying eval board with SPBTLE-1S module. I'm using BlueNRG-1 Navigator v 2.6.0. If I flash any demo application, no BLE service can be discovered on the phone (Nexus 5X, Android 7.1.1.)E.g. BLE Sensor demo - DL3 ...
Resolved! Wifi SPWF04SA Leds question
Posted on February 08, 2018 at 20:22Hi everybody!The current datasheet (https://community.st.com/external-link.jspa?url=http%3A%2F%2Fwww.st.com%2Fcontent%2Fccc%2Fresource%2Ftechnical%2Fdocument%2Fdatasheet%2Fgroup3%2Fc4%2F02%2Fe5%2F87%2F1c%2Fd2%2F4f...
Dat Tran by Senior II
  • 1979 Views
community.st.com
Posted on March 12, 2018 at 21:35Support doing a sloppy job, pull it together, or find people willing to do so Posts spanning a month with no attentionhttps://community.st.com/0D50X00009XkWv5SAF https://community.st.com/0D50X00009XkWv4SAF https://co...
AutoReconnect Problem // SPBT3.0DP2
Posted on January 29, 2018 at 21:11 Hi I'm using the SPBT3.0DP2-Module to build a custom HID keyboard. Unfortunately, the module doesn't automatically reconnect to the host-device (for Testing my Win10 PC and Android Smartphone) after discon...
SPWF01SA firmware
Posted on March 14, 2018 at 20:44Hi,I need a firmware (.bin file) to spwf01sa. I erased fimware from my spwf01sa by Flash Loader Demonstrator and now I have a problem with update firmware. Please for help
SPWF04SA WPS problem
Posted on March 12, 2018 at 06:15When I use the first Firmware version SPWF04S-170216, WPS button can login to access point.But When I upgrade to new firmware both SPWF04S-170726 and SPWF04S-171117,when push WPS Button it,s not work, it,s show enrol...
SPWF04Sx - FW1.1.0 - MQTTCONN userID
Posted on March 13, 2018 at 12:17hi,question about MQTT conection TLS:how can i sent empty userID during MQTT Communication?if parameter userID is NULL, nv_model used....thanksYoannAT+S.MQTTCONNTo open a connection with an MQTT Broker. The command r...
