2018-03-11 10:15 PM
When I use the first Firmware version SPWF04S-170216, WPS button can login to access point.
But When I upgrade to new firmware both SPWF04S-170726 and SPWF04S-171117,when push WPS Button it,s not work, it,s show enrollment attemp timed out.
Please check this issue.2018-03-14 3:46 AM
I'm attaching a console log of a WPS setup to our TP-Link TL-WR740N AP. The SPWF04S is booted with the factory pin (GPIO0) active, and the WIN81 is generated by pressing the WPS button.
I'm also appending the result of some scan, just to evaluate the crowdedness of the environment.
Could you tell more about your environment?
Regards,
Elio
________________ Attachments : WPS.txt.zip : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006HxtU&d=%2Fa%2F0X0000000b1w%2FNgK9PXY7qgMxcROlGwUmBIx1PzQkuKzgzGlHR8pSj2A&asPdf=falseWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
