2022-03-17 6:26 AM
I am using I-CUBE-LRWAN SDK LoRaWAN_End_Node application. In LmHandler.c file inside LmHandlerSend() function LoRaMacQueryTxPossible() fails with LORAMAC_STATUS_LENGTH_ERROR. I have tried with higher data rates and also tried disabling the adaptive data rate. Request some help and insights on the same.
Note: Gateway and end-node are near to each other.
2022-12-02 2:34 PM
I have the same problem in a NUCLEO-WL55JC1 with LoRaWAN_End_Node application. Were you able to fix it?
