Hi,I am porting the one of legacy VL53L1 stack (STM api ver 1.1.37.12156 ) for one of the project. This stack is stable and well tested. However, i am surprised to see the RAM consumption(5.43KB) of the VL53L1_Dev_t object. This is different in n...
Hello, Is it possible to setup ROI to read SPAD array sequentially one by one or matrix of 4*4 SPADs. I.e to get a map of the measurings?
I'm currently using the VL6180x in a project, and I'm encountering some issues where I believe the prox sensor is being reset. I'm operating in Interrupt + Continuous mode. The symptom is that after running an unpredictable amount of time, while bein...
We are using your VL6180X Proximity sensor, gesture and ambient light sensing (ALS) module for a time of flight sensing application. We are experiencing a problem with unreliable measurement results from the sensor: some sensors output a low value (1...
Everywhere I look, the VL53L1X Tof Sensor says that it has a standard fov of 27 degrees (or 16x16) and can be reduced to 15 degrees (or 4x4 SPAD array). But how do I do this on the Raspberry Pi (in python)? In your VL53L1X_register_map.h there is a f...
Is three any driver available for LPC 1769.
