Resolved! VL53L5CX:What does Status 6 mean.
More specifically, the doc's say status 6 means "wrap around not performed". What is wrap around? Is this a bad condition?Thanks,Dave
Hi ST team and community!I am trying to develop a People Footfall Counter for commercial use using the two VL53L1X Sensors on Esp32 using the Sparkun Library from the following:https://github.com/sparkfun/SparkFun_VL53L1X_Arduino_LibraryFirst of all,...
Hello,I have spent some time reading through the VL53L0X API and all documentation related to this sensor.I was hoping your team could clarify the usage of a few functions and features."Pre-Range" vs "Final-Range"This distinction is made througout th...
Hi - I can't seem to get the driver to compile on a RPi 3+..Grateful for any assistance !! This is the error message I get: pi@raspberrypi:~/VL53L3CX_LinuxDriver_1.0.5_bare_1.2.4/driver/vl53Lx $ make VL53LX_FULL_KERNEL=1CONFIG_STMVL53LX=m make -C /li...
These questions are regarding the VL53L5CX Ultra Light API, VL53L5CX_ULD_API, ver1.0.1.In platform.h there are several macros for disabling the various sensor outputs.Eg. #define VL53L5Cx_DISABLE_RANGE_SIGMA_MM. However, I do not find a macro for dis...
Hi, I am trying to build the user mode linux driver on my raspberry pi 4 for the VL53L5CX module, and when I follow the instructions in the guide for RPI, I cd into user/test and make, I get the following error:../uld-driver/src/vl53l5cx_api.c: In f...
Hi, I have followed the instructions in the PDF "VL53L5CX_Linux_Getting_started_with_Rpi.pdf" from the VL53L5CX linux driver, and I have built the program. I am having an issue now seeing the TOF sensor when I connect the VL53L5CX-SATEL board to the ...
Hi,When I use only X-NUCLEO-54L5A1 (Expansion board with VL53L5CX), VL53L5 GUI is connecting to X-NUCLEO-VL53L5A1 well.However, when I plug-in VL53L5CX-SATEL board to the LEFT, RIGHT or both connectors, VL53L5 GUI can't be able to connect to X-NUCLEO...
Hi, We are using Laser TOF Sensor (VL53L1CXVOFY/1) in one of our products.Can we use AVDD=1.8V power supply? Even though AVDD = 2.8V, it looks like IOs will work on 1.8V.
I purchased P-NUCLEO-53L5A1 including X-NUCLEO-53L5A1 and NUCLEO-F401RE.And I assembled them and connect to PC, and then I installed its driver and reboot windows 10.When connecting, the explorer open the mass storage drive (D: (F401RE)).However, VL5...
