Automotive MCUs
Resolved! PLS UDE Debugger does not change the value of global variables
Hello,I wrote some codes and it worked succesfully. Then I wanted to add some global variable for computing a value but global variables which are added later, their values did not change, altough I set the refresh period setting ( while are changing...
Msert.1 by Associate III
  • 1772 Views
Resolved! How to measure the stack remaining available size
I had to enhance the stack size using __process_stack_size__ value to make my software running and I would like to know how to measure the stack remaining size. I tried commenting out the ram init in boot.s and fill the stack ram area with a 0x55AA p...
Resolved! Contradiction in SCP5 studio generated code (clock.h)
Hi,In code generated by SPC5Studio for SPC582B microcontroller there are some macrodifinitions, which validate setting of the clock.Particularily the one (components\spc582bxx_clock_component_rla\lib\include\clock.h):/* Check ratio between SPC5_LIN_C...
Yannek by Associate III
  • 1677 Views
SPC570S-DISP CAN Frame Error
I'm currently trying to transmit the CAN frames using SPC570S-DISP.I applied it to the SPC570S-DISP using only the example source code.However, the CAN TX signal is output as shown in the picture above.Upper the picture is the peripheral Register set...
SKim.19 by Associate II
  • 1991 Views
Resolved! shelf life for SPC560P40L3BEAAY
We have confuse for shelf life for SPC560P40L3BEAAY If the DC over 2 years ,is it still Effective? Or have some risk? Do you have document for date code police or storage shelf life can send us? Thank you in advance. Looking forward to your reply soo...
JRen.11 by Associate
  • 1309 Views
Resolved! How to debug through the j-link segger
Hi everyone we are trying to debug the program in SPC560p dicovery board when we are using the UDE debugger in that we getting some errror which i mentioned below please help us in this regard ,we need configure anything in the UDE debeggerMessage fr...
