Analog and audio
Forum board changes
Resolved! Distortion of TDA7297 at 40kHz~80kHz
Hello, I would like to know the distortion of TDA7297 at 40kHz~80kHz. If it's distortion may over 1%, please give some alternatives. Thanks.Reference: https://www.st.com/resource/en/datasheet/tda7297.pdf
Mark_You by Associate
  • 2674 Views
Sampling simultaneously 8 analog microphones with ADC120
Hi All,Could you please advice. Does ADC120 support simultaneous sampling of 8 channels? Can i connect to it 8 IMP23ABSU Analogue MEMS microphones, sample acoustic signals from all microphones for further processing in DSP?
Levan by Associate III
  • 1815 Views
AUDIO RECORD
Hello,I would like to know how to record sound through microphone. I have a STM32L552E-EVAL evaluation board and I have a example provided with this card 'Demo' but after reading the recommendations I still cannot record sound via the headphones prov...
DYann.1 by Senior II
  • 1375 Views
TDA7563B DD (POwerSO36)
The original TDA7563BDD is replaced by TDA7563BPD. What is the upgrade after the upgrade? Please explain in detail. Thanks. Maybe we can replace the chip with a better one. Any recommendations? Not afraid of expensive. Just as long as it's good.
hke.1 by Associate II
  • 2877 Views
Resolved! Unknown IC
To whom it may concern, I have an IC, two diiferent IC's in fact, in my hand and it was hard to figure out what they are, their function, or any tech info. I would kindly like to ask for tech feedback, instruction, ie any information you can provide....
radara by Associate
  • 4866 Views
How to import a project ?
Hello,I found this link on the internet : https://github.com/logical/sgtl5000-stm42f4But when i download and try to open it under STM32CubeIDE, I encounter errors such as this window.Do you know how to convert to a correct format under STM32CubeIDE ?...
  • 4653 Views
  • 11 replies
TDA7498 application schematics dillemas
Dear sir,madam, I have a questions about schematics in figure 3 of TDA7498s datasheet:- should pin PGND (18) be left unconnected to ground?- pin VSS (36) is also left unconnected to ground or it is on potential (VCC - 3.3 V)?- are SUB_GND(1) and for ...
