Analog and audio
Forum board changes
Programmatically changing the auto-reload register value
I am using stm32g491ret6 for generating sin, triangle, sawtooth and square waveforms using LUTs.The frequency of the waveforms can be changed by changing the timer auto-reload register value. How I can change the auto-reload register) value programma...
SMajhi by Associate
  • 1418 Views
Incorrect audio acquisition with PDM microphone
Hi, I have a problem with audio acquisition using PDM microphones. After using PDM_Filter, single peaks of high amplitude appear in the data in addition to the correct readings. I am using 4 microphones MP34DT01-M, STM32H743 and SAI interface. I take...
RPuch.2 by Associate III
  • 3733 Views
The FDA802 High Power Output Audio waveform is abnormal
1�?An IIS audio signal that feeds a sine wave2�?High power output3�?The audio waveform is abnormalI don't know where the configuration is wrong, please help with some suggestions, thank you.The desired audio waveform
_legacyfs_online_stmicro_images_0693W00000bkA4SQAU.png _legacyfs_online_stmicro_images_0693W00000bkA36QAE.png
Jping.1 by Associate
  • 943 Views
tda7498e
Posted on January 29, 2018 at 05:48I've just managed to blow up 2 TDA7498E D Class amp chips when testing the first run of 25 production boards. This is the first time we have managed to damage any chips in over a year of prototype testing.We are us...
STP16NF06 vs IRF520
IRF520 type MOSFETs are starting to be phased out and so in all review, STP16NF06 should be a stable cross reference from what I have read, would anyone know perhaps is there a better cross for an IRF520 than the ST STP16NF06? i have ask OnSemi and t...
MRUEF.1 by Associate
  • 1377 Views
