Analog and audio
Forum board changes
Resolved! SPICE model for OA1ZHA
Hello,​I want to perform AC analysis using LT Spice. I tried to find SPICE model for op-amp OA1ZHA but could not reach it. I would appreciate it if you told me how.Best,H. Sawano
HSawa.2 by Associate
  • 1476 Views
TSC210 current leak path into VREF when IC has no VCC
There is a leak path between IN+ and VREF, through the feedback resistors when VREF is connected to GND.I need to know whether this path is still possible when the IC has no VCC applied to it.I disable the IC to save power consumption but if this pat...
JDLR by Associate
  • 901 Views
How to make voltage offset measurements for TSC2012
I am trying to confirm a series of electrical measurements of the TSC2012H and have been successful in measuring positive and negative input bias current and both high and low voltage output swings, however have been unable to make the Voltage offset...
JVoeg.1 by Associate
  • 1096 Views
Explanation on FFX and DDX and comparision to PWM.
Hello,we plan to design a fully digital Class-D audio amplifier based on STA309A/STA311B and STA516BE, STA516B, STA510A, STA510F.Datasheets of the related parts use the terms "DDX" and "FFX". But I can found nowhere any explanation what thet technolo...
ARump.2 by Associate
  • 1635 Views
