2026-03-24 7:16 AM - last edited on 2026-03-26 7:31 AM by mƎALLEm
When connecting to our stm32n6 using a stm32 Programmer we get an unstable connection. Connecting with a low clock rate (5khz instead of 8000khz) improved the Issue but there still isn't a reliable way to connect to the board. Some retries are needed to get a connection. Also after some time the connection doesnt work entierly and the MCU needs to be powercycled.
2026-04-01 8:15 AM
Hello @Nixxen,
Could you provide the error message you get when the connection fails? As a first check also try with a different cable, to rule out any cable/connection issue.
Also, are you using CubeProgrammer CLI or GUI? On my side, I am not able to reproduce the issue after several attempts, testing all available frequencies.
Thanks,
Amine.
