2022-10-04 3:39 PM
Just installed the new version 2.11.0. Never used any version of CubeProgrammer before. I am using it on Windows 10 with Java 18.0.1.1.2022-04-22. When I start it, just the start-dialog appears and disappears after some seconds. In varioius posts I have seen that this happens since years. Hints to re-install Java or use another version didn't seem to work. As the programmer is distributed with an jre, I tried to set path to its bin-directory and JAVA_HOME to the jre path, but this didn't change anything and calling java.exe from the programmer-directory just leads to a java-error message. Any hint how to get it running?
2022-10-05 3:05 AM
Hi @KBrei.1 ,
It seems to be a java issue related to your PC configuration.
As you may know since 2.6.0 version no need to install any Java on your machine, STM32CubeProgrammer runs with a bundled JRE available within the downloaded package.
To avoid any java issue, I suggest you use these steps :
Please test and tell me if it is OK.
Houda
2022-10-05 3:05 AM
Hi @KBrei.1 ,
Houda
2022-10-05 8:28 AM
Hi Houda,
thanks a lot - that last step I didn't try, as strangely jre/bin/java.exe --version stops with an error message. But indeed - the programmer runs with that approach.
Klaus
