2023-02-08 4:53 AM
If I include mx_chip wifi driver in my own project it never compiles. I am doing everything they are doing in Nx_TCP_Echo_Client example project. Now gave up on this. What dees "Check that this file is included by the driver source and not compiled directly" mean.
Kindly help.
2023-02-09 1:33 AM
Hello @Nitin
Could you start by checking if the include paths are all set.
This is could be found under [Properties]->[C/C++ Build]->[Settings]->[MCU GCC Compiler]->[Include paths]
And it would be helpful if you can share some screenshot and if possible a minimalistic project where this behavior is found.
KR,
Semer.
2023-02-09 5:01 AM
Hi Semar, Much thanks for prompt reply. I am including all the paths as same as mentioned in working example, still error is not resolving. I am sharing my sample project with you. Please let me know what is the issue. Your help will be a great learning for me as I have tried everything possible from my end.
