2020-01-31 2:08 AM
Hi all,
I am new to ST.
I am struggling with the attached code.
I am trying to transmit CAN message.
Thanks
2020-02-03 4:54 AM
You'll need to supply more information/code.
1. How are you checking that you are transmitting? CAN bus analyzer, oscilloscope? Is you hardware connected to another CAN node, with terminating resistor?
2. What baud rate are you running at? You need to supply the code that shows MX_CAN_Init() and relevant code so we can see if the bit timing is correct
2020-02-03 5:31 AM
2020-02-03 6:19 AM
Some things i am seeing that are incorrect...
