2025-09-25 3:12 PM
Issue: ST67W6X_CLI lockup
Test Setup:
Use the ST67W6X_CLI example provided with the x-cube-st67w61-v1.0.0 software package.
Send wifi_sta_connect command to connect.
Send several ping commands to verify connection.
Keep the connation active.
Wait for 5 to 10 minutes then repeat the ping commands.
Observation:
Fail to respond to atcmd AT reset required to recover.
See attached.
2025-09-25 4:52 PM
test log
time action result
3:44 recovery* pass
3:50 ping fail
3:51 recovery* pass
3:56 ping fail
3:57 recovery* pass
4:02 ping pass
4:10 ping fail
4:11 recovery* pass
4:17 ping fail
4:18 recovery* pass
4:24 ping pass
4:30 ping pass
4:36 ping fail
4:38 recovery* pass
4:48 ping fail
*Recovery scheme: send reset, wifi_sta_disconnect, wifi_sta_connect and ping
