2023-04-18 5:31 AM
Hi... for some reasons I cant regenerate my code from CubeMx but I need to change crystal 8M to oscillator 14.7456... in spite of replacing the clock function (void SystemClock_Config(void) ) with new one, my project does not work. what other changes do I need to consider for changing the clock in a project generated by CubeMx?
thank you in advance
2023-04-19 8:29 AM
Hello @Zakba.1
If your project contains any code that is sensitive to timing (e.g delay loops...), you may need to update this code and consider the new oscillator frequency.
2023-04-18 7:25 AM
Well, why not generating 2 new dummy projects with the old and new settings and comparing the output. The new freq. may be to high for the old (PLL?) settings, and oscillator != crystal ?
hth
KnarfB
2023-04-18 4:44 PM
Well I tried that creating a dummy project with new clock configuration and replaced the generated system clock function with new one... this function as far as I know configures freq, pll, crystal or oscillator type in itself... except this function do I need to change any other configs in project?
Ps: I generated the code in cube with HAL lib
Post edited to adhere community guidelines.
2023-04-19 8:29 AM
Hello @Zakba.1
