2017-01-11 9:02 AM
Posted on January 11, 2017 at 18:02
In an IAR/EWARM environment, when I use STM32CubeMX 4.18.0 Project/Generate Code function the program seems to correctly generate its own files but deletes user (that is, my files) from both the EWARM project and from the file system.
It appears this was reported for some earlier CubeMX versions too (
https://community.st.com/0D50X00009Xkf15SAB
for ex). Anyone else suffer and fix this issue?
EDIT 170112 confirmed as a regression --- non-cubic sources preserved with 4.16.0. Not sure about 4.17.0.....
2017-02-02 9:10 AM
I'm not seeing the problem with 4.19; please disregard
2017-01-11 11:58 PM
Hello
goldstein.howard
,Your issueis reportedto CubeMx team for further investigation.
Thank you for highlighting it and Sorry for the inconvenience it may bring.
Imen
2017-02-02 9:10 AM
