2018-12-24 7:28 AM
Dear ST support,
1. The following attached the issue of some pins being overwritten by the last pin configuration, I also didn't find the hide feature in the configuration pop-up.
how i can solve this issue ?
2. what is the correct configuration for 1-bit sdcard mode on BSP FATFS (Platform proposal)?
because when I was ignored then I got a warning like in figure 2
Thank you in advance
2018-12-27 11:13 AM
2018-12-27 1:41 PM
I'm not sure ST has anyone responsible for QA of the user interface, or regression testing of the software more generally. Be interesting to see the ISO docs explaining the process they use...
