2019-04-25 11:54 PM
Although I was quite excited to fire up the CUBEMX tool, I felt a little disappointed when, having selected on dev board (Nucleo etc), the tool did not then show me the mapping from the CPU pins to the board pins, with references to the on board LEDs and jumpers etc.
Also if you could attach application labels to the board pins, these could reflect back into the generated code, say as a suffix e.g. _RELAY1
I think having this capability would greatly enhance the tool as a "getting started" tutorial by bridging the mental gap between physical board and registers and software.
